sleepyboat
- Dec 6, 2010
- C-242 C
- SALLISON TOO (2017)
Did you ever leave work, drive home and because it is so routine cannot recall most of that ride at all? I believe that is what happened to me when I first read the spec’s for the R 23 when it first came out and it burned into my memory. In particular the fuel tank capacity of 80 gallons. It never occurred to me that the designers would put in different sized tanks depending on the engine option you selected. A tank is a tank, right? Well, not quite. The gas tank is 75 gal and the diesel is 80. Economy wise you will probably burn more gas than diesel. Both tanks fit in the same space, so why would the factory complicate inventory with two marginally different size tanks for the same boat? This may answer the question I had with the Garmin fuel gauge never reading full. Bad data in bad readings out!
