R-25 Windows will not open
TwoCrabs
R-25 Classic
Ruby
Only one window on our recently acquired 2007 R-25 opens. The latches on the Diamond Sea Glaze windows can be pressed to clear the frame but we cannot get the windows to budge. Any suggestions?
On my '17 25SC I used to use a 1x1/2" (ish) stick of scrap wood. About 8" long. Place one end against the inside frame. align the stick to go against the latch so the wood compresses the latch and wedges up against the protruding "finger hold" of the latch and pull the stick upwards to apply backwards pressure to the sliding window. Then I would carefully spray West Marine bunk lubricant on the window tracks. Worked great!
Thanks, I’ll give it a try.
Seems to happen to at least one widow every spring. Sometimes if you use the heel of your hand against the side of the moving pane on the outside in the closing direction it will jar the window loose. This also does not put any strain on the latch. I have had good luck with a film of O-ring lube (silicone lube in the small can, great stuff to have) on the rubberized seal after I get the window open to prevent or delay re-occurance. Put it on with a Q-tip.
