I see that new builds on the R-29 and R-31 will be with the Volvo D4 320, instead of D4 300.
I am not experienced in using performance tables of the sort Volvo provides, so I'm asking what performance differences should be expected.
https://www.volvopenta.com/marinecommer ... 4-320.html
If you click through that link into specifications you can download a PDF on performance comparisons charts.
It appears the 320 adds 100 RPM at the top, and some very slight improvements in fuel efficiency in some RPM ranges.
What is the reason for the change, and what might be expected in performance differences?
Thanks in advance.
Thanks in advance.
