Dave2016R29
 - Sep 29, 2020
 - C-30 S
 - Rock Lobster
I have a 2016 R-29S with air conditioning.  Seems like I've always had some minor electrical and battery issues, but lately the batteries don't seem to charge properly.  For example, while underway the engine battery shows 14.2v on the Garmin display, which is as it should be while charging.  However, the unit battery (house) never reaches high voltage, and in fact starts to slowly decline over time while cruising.  11.8v - 11.7v - 11.6v, as low as 11.2v.  In discussion with the yard where I have the boat serviced, they removed the ACRs and put in a manual switch to combine all three battery banks, presumably so that all banks would charge.  However, I still have the same issue.  House does not seem to charge while under way.  Is it true that I should see 14+v on the house battery meter while charging from the engine?
A related issue with the generator is that it does not seem to charge the batteries. If I combine all three of my battery banks, then I get 12.1v for all three battery banks. If I start the generator, with the AC main 1 on and the inverter in charge mode, then I still get 12.1v on all of the batteries. Should I get higher voltage from the charge from the generator? When I had the boat on shore power recently, all of the battery bank readings immediately went to 12.8v, and then were fully charged when I returned to the boat a day later. Shouldn't the same be true while on the generator?
A couple of other things I am not sure about. My AC main 1 and AC main 2 "test" button never seems to do anything. Should the breaker pop when that button is pushed? My AC 1 meter only shows any voltage when the inverter is in charge mode? Is this correct? Or should it show power when the inverter is off? Maybe all AC main 1 power goes through the inverter?
I know all of this is a but jumbled, but any insight would be appreciated.
Rock Lobster
Rock Lobster
