mlanger
- May 12, 2022
- Malaga, WA
- Website
- www.mygreatloopadventure.com
- R-29 CB
- Do It Now
There are two bilge pumps in the engine compartment on an R – 29. My understanding is that the aft bilge pump runs on a timer and the forward bilge pump runs on a float switch. i’ve been on this boat for more than 450 nights in the past 20 months and I have heard the aft bilge pump activate periodically. I do not remember ever hearing the forward bilge pump activate.
What I’m seeing right now is that the forward bilge pump is running every 2 1/2 minutes, emitting a buzzing sound but, obviously, not pumping anything. This buzzing sound can be heard throughout the boat and it kept me up half the night. I know it’s the forward bilge pump because when the sound occurs, the indicator light on my DC distribution switches for the forward bilge pump lights up.
Can someone tell me if the forward pump is also timer based? And, if so, why haven’t I been hearing it? And how can I get it to stop buzzing so I can sleep at night?
I am seven days away from completing my great loop trip. The aft bilge pump was recently replaced and works fine. I look under the hood every single morning to check the oil and other things, including whether there is water in the bilge. If I were to pull the fuse for the forward bilge pump, would it stop the periodic buzzing or completely disable the pump?
Please, only reply if you know the answer. I can guess but I don’t need more guesses. Thank you.
