R-29 Holding tank vent
Canyonbat
R-29 S
Flips Ahoy
Is there an easy way to access the back side of the holding tank vent through hull on a 2021 R-29S? Is it reasonably easy to change out?
Follow up. Apparently, the vent through hull is accessed via a monkey fur covered panel at the forward end of the cave. Does anyone know if this panel is easily removed?
On my 2019 R29, there are 2 access panels at the forward end. The one on the port side is at the bottom of the bulkhead and is velcroed in place. The one to starboard is is at the top right corner of the bulkhead, and is held in place by 2 screws (square drive.). You’ll want the starboard. There’s a lot of stuff in there, probably including the vent through-hull. Sadly, you’re going to wish you were double jointed.
