R-29 Thrusters remote control
jimschu
C-242 C
FMLT2355A818
Seascape
We have had no problems with the remote control for the thrusters until yesterday when it could
notcontrol the thrusters. I changed batteries but still no luck. When the power button is depressed
the remote unit lights up but either tgruster will not operate.
Any suggestions would be greatle appreciated.
Jim Schu
With mine First I need to turn on acc switch on the dash Turn on the thrusters..Then hold down both on buttons at the same time then it flashes then it works
Hope this helps
When the remote is installed, there is a process for syncing the remote and the unit it talks to, which is a box that is wired in under the the thruster control at the helm. Perhaps for some reason your remote is no longer synced up with control?
Gini
Turned the dash acc switch to the on posistion, turned thrusters on, held both on buttons on the remote and lo and behold the thrusters now ooperate with the remote.
Thank you for the feedback.
Glad it's working ... The only time I have used mine is to show people .. Im sure at some point the remote will come in handy but so far have not had any situation that needs it.
Mark
