R-29S Wine Cooler-Temperature Control
dwwdfw
C-30 S
Dis and Dat III
Now that it has gotten hot in Maryland the wine refrig on my 2017 R-29S struggles to maintain temperature below 60F. Has anyone else had this problem?
The Dometic web site says the wine cooler will cool up to 34 degrees below ambient temperature, so if the temp in the boat is over 94, the unit won't be able to cool to below 60. Otherwise, you may want to check the air flow behind the unit to make sure the heat can escape.
