R-31 CB TV stuck, won’t lower
Salty Gal
C-302 SC
Scout
Any tips on how to lower my TV above the steering station on my R-31 CB? I had this problem occur when the boat was new and it was worked on as a warranty issue, but now it is stuck in the up position and I can’t lower it again. I tried lubricant, channel locks to collapse the spring, lightly tapping on the right side of the lower bolt, rubbing my belly and tapping my head, and saying acrabadabra, but to no avail. Thank you!IMG_2643.jpeg
I haven't seen this before. Can you lift up on the TV to get pressure off the pin and then try to slide the pin.
No, I tried that as well. It worked for a bit after warranty work by Pocket Yachts but is stuck again. Ours is a 2022 model. Can I get a new mount seeing as the warranty fix didn’t work?
