tlkenyon
- Sep 30, 2010
- R-25 SC
- Non-Fluid Motion Model
- 3 kayaks, 1 canoe; R-21 (Nellie May I)
- Nellie May
This probably applies to all R21's, but my only experience is with the Classic.
On a hot summer day, I was curious as to the amount of heat buildup in the engine box. I took one of those indoor/outdoor thermometers and put the outdoor sensor in the engine box, on top of the fuel tank. After a short time, the engine box temperature rose to 110F and kinda stayed there. After shut-down, the temp rose to 121F and stayed there for what seemed like hours. Since that first test, I have kept the sensor in the engine box and positioned the display so I can see it underway. Pretty much regardless of the weather, the engine box temp rises to over 100F and stays there, going up t 120+ after shut-down. BTW, I have an engine water temp gauge, and it is in the green all the time, so excess engine heating is not a factor.
Has anyone come up with a ventilation solution in addition to the stock vents? I do not really want to move the batteries and fuel tank, as they work pretty well where they are. I am concerned over the heat stress load on the batteries mostly, but also the heat stress load and aging on all the components in the box.
I am thinking of a thermostatically controlled blower, but am not sure where to direct the discharge such that it will be effective, but not pose problems with fugitive engine noise and unwanted heat in the cockpit.
THANKS IN ADVANCE,
TK
Is this a real concern, or am I making a mountain out of a molehill?
THANKS IN ADVANCE,
TK
