sheral
- Mar 23, 2015
- C-24 C SE
- FMLT2114H415
- Sheral Ann (2015 R-21EC)
Just trying to figure something out here...
Finally popped the boat in yesterday (due to having been visiting family etc). I had a new impeller in place, had run fresh water into the strainer basket, and ran the engine to ensure everything was working / pumping correctly.
Raw water intake petcock was closed. Drove to the launch. Submerged the boat (intake in the chuck). Opened the petcock and tapped the sea strainer lid to ensure it was full of water. Started the engine and the impeller was not pumping water out the exhaust. Shut it down, rechecked the petcock, refilled the strainer etc. and finally after several / numerous attempts the impeller began pumping.
So my question is (I even pulled the boat out and checked the intake to ensure there wasn’t any weeds etc blocking it)... these pumps are self-priming aren’t they? Can you think of what was up here? Air lock?
And in thinking about this, the suction / pull of water up from the raw water intake is based on suction right? So if my strainer lid wasn’t on tight enough that could prevent water from being pulled in? Thoughts? Thanks.
