ohioan55
- Aug 25, 2015
- R-23 (Outboard)
- FMLT2314C424
- Jersey Girl
I'm trying to source the correct wiper motor to replace a bad one (port side) on our 2015 R21ec. The part number on the one removed is 27210. I can't find one, so maybe Marinco doesn't make this model any longer. After contact with Marinco, they suggested a model that is listed as non-compatible with pantograph wiper arms (which I have). So, is the origonal an API 1000 motor? Is the sweep indeed 65 degrees? The shaft length I measured is less than 1.5 (~1.25"). Can you steer me to a better part number for a replacement motor?
