OhCapMyCap
- Apr 26, 2020
- C-24 C
Hi All,
New Boater here. I wanted to see if anyone can help me figure out next steps for my current situation.
We pulled our R23 out for the winter last fall and fully charged the House and Engine batteries before we winterized her, and left her in the yard. We left the switch for the House in the on state, and left the one for the engine in the off state. We put a cover on the boat for the winter, so the solar panel was not able to charge the batteries while in the yard.
We went to start the spring maintenance on the boat on Sunday, and we put her in the water to go to the Marian. When we launched, we realized that we left the House battery switch in the On state and it wasnt reading any charge. We realized we left the outside lights on all winter, which cause the House battery to deplete.
Once we put her in the water and started the engine, we ran the emergency parallel with the engine battery to jump the house battery. We flicked off the emergency parallel after a few min of charging, and when the house battery came back to life on the screen. But when we got to the Marina, turned off the engine, and plugged in, we noticed the lights did not turn on. We had to flick the emergency parallel again to jump the house battery (while on shore power) and turn the lights on.
I'm trying to figure out what this all means, and what my next steps are. Do I need to check the health of the batteries? Does it sound like I need new House batteries? Should I replace all the batteries?
Side note: We realized that we also left the Thruster battery switch in the On state all winter. While underway, the thruster did not work. Only after we got to the dock and plugged in, did the Thruster start to work.
So with all that in mind, does it sound like I might need to replace my batteries with fresh ones? Or is this normal activity after de-winterizing?
Thanks!
Sean
Thanks!
Sean
