What year is your R23? Is there water in the pod or just a stinky smell from wash-down water when used?Sager":3ewlu6tq said:Does the transom engine pod normally stay filled with seas water? Does that sea water feed the rear deck seawater wash down? I am noticing a very stinky smell from the rear sea water wash down.
This issue has been discussed at length on previous posts. The engine pod on the R-23 has a bilge pump that should keep the pod relatively dry IF the pump hasn’t failed. If it has failed water will accumulate in the pod. The factory made a change in the access cover to replace the original access cover to a watertight cover. Bottom line is check the bilge pump to see if it works and change the access cover. There is a drain plug in the center of the pod that can be removed to drain any water in the pod if you are out of the water. Hope this helps.
Karl
