You can get extra shear pins,fuses,and locking rings here.
http://www.marinewarehouse.net/ Go to docking, then thrusters. The shear pin is #32050
I Keep extra of all these in my spare parts kit that on board. It is also good to have extra fuel filters,impellers, belts,zinc's,bulbs, and so on. I feel it is good to take the time to get familiar with the parts of your boat that I call easy fixes. Make sure you have the right tool to get to lets say the water pump impeller. When I first got my boat I spent time making sure my tools could get to the bolts on the water pump and other things on the engine. I also pulled my thruster apart (two bolts... no big deal) to get familiar with that. I would rather fix something knowing a little bit about it so if I am out at sea and the boat is rocking, at least I am not staring blind with a failure.
Most things that will cause you to go dead in the water or anything like that are easy fixes. Having a good spear parts box is wise. It does help to be a little mechanically inclined to take some of this on. None of it is rocket science and if you can change a car tire then one could most likely do this kind of repair work.
I am speaking generally and not at you directly Sparky when I talk about this stuff. Just sharing what I do in case someone out their is interested.
P.S. Spend lots of time docking your boat without thrusters. Then when they fail, and they will, you will have that experience also.
Stuart.... Spirit of Gratitude R-29
