TomG
- Aug 8, 2018
- C-26
- FMLR2506G314
- Coddiwomple
New, totally different, never before heard of Thruster issue.
Coddiwomple* is a 2014 R25SC. The bow thruster has been on again off again for the last year. I've got new toggle switches and a new stern thruster motor. I installed a new solenoid on the front motor to no avail. So now I've received a new motor assembly (includes solenoid and IC switch) and when i set it in place it won't fit. The cross support piece that was built into the bow is in the way. I measured the two motors and the new one, though it has the same part number as the old one is about a quarter of an inch longer. They've redesigned the housing over the electrical end of the motor.
Should I grind down the support in the bow a little? Should I send the motor back to Imtra or try to find a rebuilt older style motor? Should I remove the cover put it in a vice and reshape it to fit? Has anybody else had this problem?
Thanks, in advance for any help!
Tom
*Coddiwomple: Old English term meaning "Traveling purposely to an unknown or vague destination"
Tom
