A Andrew Custis Staff member Factory Employee Joined Nov 21, 2008 Messages 1,389 Fluid Motion Model C-24 C Dec 1, 2008 #1 This is a pretty accurate fuse layout I have tried to do with the older R25's that dont have fuses labeled in the battery compartment. If it is not the exact same at least you will get the idea by the size of the fuse. Attachments Fuse Layout PDF.pdf Fuse Layout PDF.pdf 13.4 KB · Views: 1,154
