shawnpb
- Sep 16, 2020
- C-248 C
- FMLT2544G708
- MOKUHONU
My Headmate started having problems a couple of weeks ago, back pressure developed and bowl wouldn't pump out, literally so much pressure built up, handle wouldn't go down. I researched and decided to tear apart the pump assembly and give full inspection. All pieces looked ok, nothing installed incorrectly. With pump assembly off, I snaked the discharge line, but my 25' ft snake would not make it to the main tank, it just stops. With no ideas, I put everything back together, filled bowl with water, pumping started out very smooth, but soon too much back pressure developed and couldn't pump. I can't imagine the discharge line being so clogged I can't snake through it! I'm gonna try disconnecting the discharge line from the holding tank side and run my snake in the reverse direction, but that is proving to be very difficult. Anyway, anybody have any thoughts?? Thanks!
