The Yamaha F250 and F300 both use the same service manual. They're that similar. The R27 and R25 are close in size and weight as well. Also note, we pay little attention to weight. We bring what we want on the boat and go. (We don't spend any effort trying to lighten the load to get better fuel efficiency). The F200 on the R23 is a different service manual, different engine.
The F250 and F300 are recommended to run with 89 octane per Yamaha. The Yamaha has knock sensors so running 87 octane won't hurt, but results in less horsepower. On Puget Sound I can get 89 octane at Des Moines and Oak Harbor. Everywhere else that I've found has been 87 octane. Channel Surfing gets the 'good stuff' on occasion, but generally is running on 87 octane (ethanol free gas only). 87 Octane with 10% Ethanol is 85octane fuel, and the ethanol increases the octane to 87. I'll always take ethanol free every chance I get.
For a 2021 R27-OB with the Yamaha F300
For planning purposes using Navionics, I use the following data:
Slowboat: 6.8kts at 2.5gph.
Cruise: 25 kts at 16gph.
More details...
We can slow boat at 6.8kts, 2.8nmpg, 2.5gph at 1700rpm. The slower we slow boat, the better the fuel economy would go (seen as high as 4nmpg)
If we slow boat on the 9.9kicker, we get approx
1gph at 4.8kts at 7/8th throttle.
On the main engine, at cruising, 4500rpm, 25.5kts, 15.6gph and 1.6nmpg.
The best fuel efficiency is between 4200 and 4500 RPM, depending on sea conditions.
Engine trim is 2 or 3 dashes only.
WOT is 35kts. 5600 rpm, 27gph, 1.3nmpg. Get there super fast and spend more time enjoying the destination.
At 10kts I see 1.9nmpg, which is close to what I can obtain doing 25 kts.
Faster than 10kts and slower then 22 kts, is pretty much how to burn fuel fast and get not much for it. (Inefficient).
(Faster than hull speed but slower than planing speed)
On plane, depending on conditions of wind and current, I see 4200-4700 rpm, between 22 and 28 kts.
At 150 hours on the engine, traveled 1,526nm, 968 gallons of gas consumed, we averaged 1.57nmpg (1.8mpg) over this summer.
Hope this helps.
