Subject: R25/OB Webasto heater's temp sensor location?
Anyone know where the temperature sensor for the Webasto diesel forced air heater is located on the R25/OB NW Edition (mine will be a 2023 model)?
Its control display is in the port side cave's aft wall and wonder if the temp sensor is Part of the control box or if there's a wire running from this control box to some other location in the boat.
Was at the Seattle Boat Show on Feb 4, 2022 and was climbing all over the R25/OB they had on jacks and on display. Took as many photos as I could. I noted the forced air outlets are at various locations...
1) Large always-open rectangular vent to port side of the Nav seat. (I'm a bit concerned small items could fall through this vent)
2) Round flap open/close vent on port side below fwd stateroom's TV directing air in the berth area
3) Two round flap open/close vents on upper helm's starboard side - presumably for defogging the front and side windows, and for providing some heat output.
I attended the Seattle Boat Show yesterday Feb 4, 2022, and visited the Webasto booth. They had two models for the Webasto heater. I believe the small one (the smallest one made by Webasto) is used for the R25/OB and its model number is AT2000STC. It's spec sheet mentions SC1600B Room Thermostat with integral On/Off Switch and indicator Light.
As an aside, these Webasto heaters push their exhaust gases to the outside of the boat, and from my experience using this heater on past RT NW Edition boats find the exhaust noise is quite significant and comes close to being characterized as sound like a small wind tunnel running at speed. I chatted about this noise with the fella at the Webasto booth and he indicated there are mufflers made by Webasto that can lessen this noise level! BY THE WAY ... this Webasto Air Top AT2000STC 7,000 Btu heater's complete kit was listed at $3,521.61.
