R27 120v outlets
ronmaloney
FMLT2733K011
Tugalong
Purchased a 2011 R27 this year and still trying to figure out how everything works. When plugged into shore power, the 120v outlets on the port side do not work. There is a switch for the head outlet which also activates the outlet in the galley (both starboard side) but I can not find a switch for the port side nor can I find anything in the boats manual which helps.
I assume it is something simple but I've tried all the switches on the panel. I ideas?
Our 2014 R27 has a separate breaker on the AC panel for the Port and Starboard outlets.
I hope this helps.
On our 2011 R27, the A.C. outlets are labeled "Head" and "Dinette on the breaker panel, " which translates to starboard and port.
The first outlet in series on each side should also be a GFCI which may be tripped. Look for an outlet under the dinette forward seat to reset it. Possibly in the cave near the aft wall, I can’t remember which direction the circuit runs.
Curt
My 2011 has breakers for head, galley and dinette. Although the galley is on the head circuit. As Curt said there is a GFCI under the dinette that could be off. See if you can reset it.
Thanks, didn't check for the GFI. Flipping the dinette breaker didn't work so I'm guessing it is the GFI. Will check the next time I'm at the boat.
You guys are an awesome resource for a converted sail boater, which had basic electrical, to a tug which is more complicated than my home.
