We received the boat late last season and found the fresh water tank didn't seem to be venting properly. The symptoms included:
1) When filling the tank, no air noise or overflow water seen at the vent.
2) After screwing in the filler cover, water pressure would reduce until hardly any water would come from the faucet. On opening the filler cap there is a big hissing sound as the vacuum in the tank is equalized. Then the water pressure would be fine again for a bit.
Yesterday, I decided to see if I could confirm the vent line is not kinked or compressed in some way. I removed the refrigerator and disconnected the vent tube from the hull opening. Nothing obvious was wrong. I put some air pressure in the tube, but it seemed to be either clogged or has a check valve (unlikely).
I couldn't see the tank connection from the fridge compartment, so I wasn't able to confirm anything on that end of the vent tube.
I spent about an hour searching through the forums and couldn't find an previous post that might help.
Is the fresh water vent clogged or is there something else going on?
if so, what have owners done to fix the situation?
All suggestions, insights and comments are welcome.
Thanks!
Roy
Fin Fisk
Lake Pepin (Mississippi River)
Pepin, WI
Thanks!
Roy
Fin Fisk
Pepin, WI
