Smcavana
- Jun 5, 2017
- C-28
- Restless
On our 2011 R27, new to us as of late last year, the wheel has a little play and turns 4-1/4 turns pin to pin. If we mark the center rudder position (by turning the wheel back 2-1/8 revolutions) and then repeat the process, the center is no longer in the same position, and it keeps moving if we repeat the process more times. Is this normal with hydraulic steering (we're used to mechanical steering on our sailboat) or does it indicate a problem-- air in the hydraulic lines? Also, how can we eliminate the "play"?
