Midwest Jeff
- Mar 22, 2023
- C-28
- Non-Fluid Motion Model
- Looking to buy R27
As we finally got the boat in the water, and are starting to use the systems. The fresh water pressure is not great, especially at sink. Also, pump is extremally loud. Normal? This is a used 2023 with only 45 hours on it. Pump and faucet filters are both clear. Connections look good with no leaks. Pressure starts out decent, but falls off quickly. Not expecting 60 pounds of pressure, but it's little better than a trickle. Next step is to pull the pump and check the impeller. Thanks
