R27 Velair AC Not cooling
NewTuggerNY
Scallywags
Just took delivery on a 2026 R27 with twin 150's. The Velair AC does not cool properly. A few observations. Cabin is 82 degrees, If I set the thermostat to 72 the fans come on and blow air but it is not cool, compressor doesn't kick on and no water pumps. It will only begin pumping and compressor kick on if I set the thermostat extremely low, say 61 degrees. At that point the compressor kicks on and water pumps with a good flow. Air blows cold ish, but not enough to cool the cabin. even running for over an hour barely drops the temperature by 1 or two degrees with ambient temperature outside in the low 80s. I did check the out flow and water is not warm at all. Anything else I can check?
