R27 vs C28
RonB
Comparing these two boats, where is the extra foot located on the C28? Is the v-berth the same size?
Ron
It is really tough to try and compare these boats because they are completely different in terms of layout and handling. If you were comparing the 25SC and the 27, the answer would be simple. If you were comparing the C26 and 28, the answer would be simple.
Feel free to reach out to me directly and I will be sure to give you my take on all of the models.
Andrew Custis
(253)230-0727
andrewcustis@rangertugs.com
Thank you, Andrew, for calling me yesterday to discuss the differences between a R27 and C28. A key difference is that the Ranger Tug is more of a go-slow boat as compared to the Cutwater. The R27 is also lighter and therefore gets better fuel economy and is easier to tow.
Concerning the question whether the V-berth is bigger in the C28 than in the R27, Andrew confirmed that they are essentially the same (6' 2-4"). Since both my wife and I tend to spread out a lot while sleeping, I'm wondering whether the V-berth in the R27 or C28 is roomy enough to sleep comfortably for both of us.
So, for those of you that own a R27 or C28, how do you find the comfort level of the V-berth?
Ron
It depends on how tall you each are and whether you can sleep with you feet touching. I am 5'9" and my wife is 5' 6" and we both fit fine as long as she stays towards the bulkhead. While there is over 6 feet of length that only applies for one person. Feet start to collide at 5'8" or so. Also, while there is over six feet of length, that is only in the corner. I would think that at 6 feet or so the shoulder room starts to be compromised and your head may need to be tucked in the corner. Of course this assumes you are stretched out straight without bending your knees.
Incidentally we added an extra cushion to extend the midship berth (cave under dinette) so that you don't need to squeeze your hips into such a tight space. My wife insisted she try all the berths before having guests and she says the midship berth is the most comfortable as it has the most room and rocks the least (because it is lower in the boat). We have since had couples overnight in the boat several times with no complaints!
On another note, I would recommend softer cushions or memory foam added over the top. The cushions are very hard and this is from someone who likes a very hard mattress!
If you want a comfortable bed look at the bigger boats with the modified queen berth.
Yes, a R29 is an option, but there are other considerations when towing a bigger and wider boat. So, I'm still interested in other people's experience when sleeping in a R27 or C28.
Ron
I am 6'3" and I sleep in the v-berth. The Admiral likes the depressed dinette table with an extra 3" memory foam pad.
