R29 2010 aft 120v outlets (cockpit and starboard locker)
RangerLove
C-288 C
Folks,
I'm failing to be able to turn on my aft 120v outlets. I have one in the cockpit on the back sink/propane locker, and the other is in the starboard locker that houses the generator and diesel furnace.
It could be simply replacing the fuses on each of them (which I'll do over the coming days) but there is a breaker that I anticipate them being on. I currently have V-berth outlets, Galley outlets, Saloon outlets, but no cockpit outlets.
Any ideas/suggestions are welcome.
Thank you!
Check if one of your outlets is a GFI. It may need to be reset.
On our 2010 R 29 there is a circuit breaker on the Ac panel. It’s labeled as an accessory. The outlet also a GFI breaker.
Jim Demerest
2010 R29 Chessie
Thanks guys. Found it, and re-setted both GFIs. It was an unmarked AC breaker that needed to be on for both GFI resets.
Much appreciated.
