R29 hatch lifter
rhaviland
C-288 C
FMLT2931B111
TUG TIME
The hatch lifter on my 2011 R29 has quite working. Is there a better unit then the one that came with the boat? I heard that Ranger Tugs does not use this model any more.
Roger
Hey there Roger. Good to hear from you. I would suggest getting in touch with the guys at Wefings who you purchased the boat from. They should be able to get you taken care of. Just because we don't use the electric hatch lifter anymore doesn't mean we won't be able to find you a replacement. I believe they are still manufactured so we shouldn't run into any problems.
Thanks Roger,
Andrew Custis
I am on it !
Original is a U Flex AV 6012 40584 H 12V DC 600 mm (24")stroke 977 mm (38.4")overall length 48 mm (1.9")
Lenco makes a almost exact replacement . Ill find the best solution .
Marc
This is why I love Ranger tugs, try getting this kind of input and service from another brand.
Will post results of issue for general info here .
We are all about service at Wefings .
Marc
Our electric hatch will only operate up or down 2-3" each time the switch is depressed. I must release the switch wait one second and depress again to raise or lower another 2-3". Do I have a switch issue or a motor or other possible issue. Thanks
