griervictoria
- Feb 6, 2014
- C-302 C
- The Glasgow Ranger
I found recently that my house fresh water pump was not working. The water level indicator came on, as did the water pressure light at the 12v panel. There was no fuse issue and Steve Phillips at Canoe Cove Mfg reported that there was power to the pump. He said the fastest and most economical solution was to replace the pump, which he did and $400 later all is working fine. My question is how common is it for a pump (Johnson factory installed) to fail after only two and a half seasons and 200hrs engine use?. We don't take 15 minute showers or use excessive water.
Is it worth getting the original pump looked at and keep as a spare? Thanks Jim Grier
