r31 AC power distribution
sailor1man
R-31 CB
FMLT3117L920
Petrel
schematic posted does not look like my 2020 R31 CB, no rotary switch on boat, need AC and shore power schematic
You did not post a schematic and did not state if you have a Generator or Marine Air.
The rotary switch should be located on the bottom of the breaker panel. The 120 volt meter is above the rotary switch. This is for a double 30 amp 120 volt shore power panel.
download/file.php?id=731
If you do not have Marine air and generator you will not have a Rotary switch. It will have a single 30 amp shore power receptacle.
If you have a LE and Generator, there is no rotary switch on newer models.
AC power controls are on the panel to the left of the cave entrance. There are 4 AC breakers (top to bottom🙂
Shore 1
Generator
Shore 2
Parallel
Shore 1 and Shore 2 bring in power from the cockpit plugs.
Generator and Parallel are used with the Genset to bring AC power to both AC circuits.
Shore 1 and Parallel can be used in conjunction with each other to run the A/C when only shore 1 is getting power .
Hope this helps.
Patrick
