R31 generator operation
barling
C-302 C
Bristol 29.9
Barling
I have finally had the generator on our R31 fully serviced. After running the generator for two minutes to warm up, how do we have it (1) charge the batteries or (2) use the microwave or (3) use the electric stovetop (4) or use any of the electrical plugs, or do whatever we may do with it?
You have all kinds of options.
Cruising the main engine running and Generator running. Air unit on for air conditioning, outlets on for galley, head or stateroom, stove top or oven for cooking and Ice maker. You don't need to have the hot water heater on because the engine is heating the hot water heater, you don't have to have the battery charger on because the engine is charging the batteries.
Cruising, the main engine running without generator and using the inverter, outlets, Microwave are usable. You still have hot water, your batteries are being charged, your outlets are available to power 120V appliances, you can cook with the Microwave.
Anchored, and using the generator. Air unit for air conditioning is available, battery charger if you need to charge batteries, ice maker, stove top or oven, microwave, outlets, anything that is used on shore power can be used using the generator. You should use some power management. Don't have the hot water heater, air unit, stove top, ice maker, battery charger all operating at the same time. It will put the generator into overload.
Anchored and using the inverter. You have a large battery bank for the house. If you have been cruising and have the house bank fully charged you can use all the outlets and the microwave while at anchor. The hot water in the tank will last quite a while so no need to have the hot water heater on initially. All 12V accessories are available. If at anchor and you see the house bank at or below 12.3 V it is time to start the generator and charge the batteries, turn the ice maker on to make some ice and turn the hot water heater on to replenish hot water in the tank. If the generator is running get the most out of it.
Review the owners manual electrical section to understand the circuits.
viewtopic.php?f=7&t=12286
download/file.php?id=731
There is a rotary switch that is shore power, off, generator. To use the generator the rotary switch must be in the generator position. To use shore power or inverter the rotary switch needs to be shore power. The R31 should have the auto transfer switch which will turn the inverter on when shore power is disconnected. Make sure you understand this feature. If you do not have the Charger/inverter manual go on line down load and read the operation manual so you under stand the functions.
Thanks Brian for the continuing information. However, the column of 120 does not include a switch for battery charging, as it does for microwave or stovetop.(I have an Origo alcohol stove so I won't be using the electric stove.) My primary use anchoring out is the refrigerator, lights, maybe some tv news or weather) which all come from the battery bank. How do I have the generator charge the batteries should I need to charge them? Thanks.
When the Generator is on the inverter transfer switch will turn the inverter off inverter mode and the charger on this will start charging the batteries. If you have a ProMariner Charger/inverter owners manual read through it so you know full operation of the unit. If you don't have the manual go on line and download the manual. You will understand how it works after you read the units functions.
