Gin
- Dec 12, 2012
- R-31 S
- Echo II (2019)
Hi All. I’m hoping to upgrade the solar on my 2019 R31 soon. I know I need to make sure that the amperage does not exceed the rating for the 10 gauge factory wire that is already in place (since I do not want to try to run a new wire). To calculate that requires knowing how long the run is from the controller to the panel. The wiring is mostly in the innards of the hull walls and behind the cockpit ceiling panels.
Does anyone know the approximate length of that wire run? If the factory ran the wire as part of a wiring harness, it might be something other than a reasonably direct route and significantly longer than might meet the eye’s guesstimate.
Gini
Gini
