calcman05
- Feb 3, 2024
- Bellingham WA
- R-31 CB
- DINGLEHOPPER
For the last few years I've had issues with overheating on my D4-300 on my 2015 R31CB luxury edition. When I go above 3000 RPM, generally the temp jumps to 196 and then goes up from there ( I've seen it hit the 200s, but immediately throttle back so I drops back to 185). The temp spike happens on both the Garmin and Volvo monitors.
Not my main concern, but as awareness my WOT is usually 3200. It won't go above.
Video of this -
In the past few years I've had a new turbo put in, as well as had the entire cooling system gone through, including heat exchanger, oil cooler, fuel cooler, trans cooler, after cooler new thermostat, new coolant and impeller. The cooler cores were disassembled and bored as well. The shop also updated my engine with the latest Volvo software last fall. I have also blow air through the seawater intake in reverse to ensure there are no obstructions. All this work was done by a reputable shop.
The boat runs like a dream under 3,000 RPM....it could run all day and never go above 185...so I'm trying to figure out if there is anything to look at next, any thoughts?
- Larger seawater intake?
Video of this -
