R31-S Lewmar 1000 Windlass Annual Maintenance
Kaptajnen
C-302 C
Akvavit
Our 2018 R31-S is equipped with the above windlass. What annual maintenance, if any, does this item require?
Not much. Usually the only requirement would be to tighten the clutch if it starts slipping. Make sure all you electrical connections are good. If something goes wrong then it is more fixing than maintenance. Usually the issues will be a switch solenoid or motor.
Hi Kaptajnen,
As knotflying mentioned, not much other than keeping it clean and checking for proper operation. Your manual will have any maintenance listed that Lewmar requires.
Cheers,
Ralf
