R31CB lift.
bill46
C-302 SC
FMLT3107F314
Radio Active
Do you have specifications for bunks for a boat lift?
Trailer dimensions would help if not.
Do you know the weight with fuel and water?
Thank you Bill
Hello Bill,
I am sorry but we do not carry boat lift dimensions or trailer dimensions. All of our trailers are custom designed by EZ Loader who hold onto their build sheets they have created for the boats. You might talk with your local Ranger Tug or Cutwater dealer you purchased from to see what others have done and who they worked with to help you determine a fit for your lift.
Thank you,
The spec sheet you will find here http://www.rangertugs.com/Userfiles/Doc ... 6-0955.pdf, shows the dry weight being 11,500 lbs. If I calculate the fuel tank @ 180 gallons @ 7.1 lbs per gallon = 1,278 lbs. Water @ 80 gallons @ 8.36lbs per gallon = 668.8 lbs. Holding tank @ 40 gallons @ 8.36 lbs. per gallon = 334.4 lbs.
11,500 lbs dry weight
1,278 lbs. fuel weight
668.8 lbs. water weight
334.4 lbs. holding tank weight
Total = 13,781.20 lbs APPROX
thanks Andrew
I guessed 14,000. planning to get 16,000 for some safety.
Will ask dealer to measure trailer.
I did on a purchase visit, but lost my notes.
again thanks.
I have a new (to me) 2013 R-31S and installed a16000# lift manufactured by Synergy Boat Lifts (Synergyboatlifts.com). They had previously made a number of others for this model boat, a couple of which are in the Tampa Bay area and I live in Cape Coral. I'm very happy with mine, so far. It is their standard 2 motor, 6 piling model except for raising the bunks to accommodate the keel. The owner of the company was more than willing to talk with me at length prior to my purchase.
