Phoenix
- Jan 30, 2009
- C-26
- FMLR2503E
- Squirrel Tug II
Hi Andrew & the folks at the Factory:
We are the proud & delighted owners of a 2009 Ranger Tug R21EC, Squirrel Tug, purchased from Port Boat House in Port Alberni on Vancouver Island. We live in Squirrel Cove, Cortes Island, BC (& are new Tugnuts). We recently took her to Altech in Campbell River for her 50 hour service. We have 5 questions/issues arising out of that service.
1. Altech was not happy with the fact that the factory installed Racor did not have a plastic bottom to detect the presence of water. They suggested installing an RK20726 Racor Guage (Audio/Visual) Probe Kit (which sets off an alarm when water is detected in the filter). What do you think of that idea/suggestion?
2. They also found the location of the Racor very awkward. (It is exactly as in Andrew's December 2008 photo.) As the photo shows, it has pipes under it, is very close to the floor, & therefore awkward to remove to change the filter or drain. Do you have any ideas to make this easier? Is there a special reason why it is positioned where it is? What do you think about moving it higher up to improve access?
3. Someone at Port Boat House suggested checking for water in the Racor prior to each outing (i.e. turn off fuel cock; place bowl under filter; remove plug at bottom of filter; drain contents & check for water in fuel; replace plug; & turn fuel cock back on). Do you suggest doing this before each outing & is this the correct procedure? (Naturally this makes question #2 even more relevant because of the awkwardness of getting to the plug at the bottom of the Racor.)
4. We bought a small Solar Panel to trickle charge the battery while anchored when cruising & when the boat is moored without shore power. (We have installed a charge regulator to avoid over-charging.) The most convenient place to plug in the panel would be the 12V/cigarrette lighter type outlet in the cabin. Is this really the best place to plug it in? Don't we have to have the master switch for house voltage switched on to trickle charge this way? And is there any problem leaving the battery switch on when moored & unattended for a few days?
5. Finally...Is it a good idea to plug in the shore power (with an extension cord from the house) to keep the battery charged up when the boat is being stored over the winter on the trailer beside the house?
Sorry, Andrew & Co. to ask so many questions. Thanks for your help & best wishes,
Simon, Barbara & Squirrel Tug.
