Ranger 21 EC, 2013, ENGINE FLUSH
Stewartn
C-24 C (Sterndrive)
Would like to use the Fresh Water flush T for back flushing the raw water intake. With the engine Off and sea cock open, may I attach garden hose to clear any debris in the raw water intake? Pls confirm this will not damage the raw water pump or impeller. As always, Thx.
stewartn@optonline.net
Don't do it! Unless you have a way to isolate the engine, you have a possibility the water pressure might hydro locking your motor!
A better way is to disconnect line at the T , and block with a fitting you can get at any hardware store.
This will eliminate any chance of water damage to your motor,
You could also put a valve in line for future use.
Bob
Ditto Bobs response! DO NOT FLUSH THE RAW WATER COOLING SYSTEM WITH GARDEN HOSE PRESSURE! Use my 5 gallon raw water flush method. It’s safe effective and does the job.
Cheers!
Karl
