Steadfast
- Feb 21, 2016
- C-248 C
- STEADFAST
Having a problem with Keel Offset......I believe it's a setting that you can change under MY BOAT and alarm settings???
I'm not sure what the minimum depth should be for my boat. The Keel Offset takes into account the number of feet? that the sensor is located beneath the water line?
I asked my dealer about it and he wasn't sure if it should be set for +3 feet or - 3 feet?????
Any suggestions.......Also my depth gauge (GARMIN) always seems to be way off.....is there a way that it can be simply calibrated? I think I'm going to have the boat out of the water this week to do replace the prop.....is that a good time to check out the depth sensor. No comments about the prop, please! LOL!
Thank you
Thank you
Thank you
Thank you
