Ranger Tug Dinghy/West Marine RIB 260
gerryt
C-30 S
FMLT2930B919
Surprise
Interested in adding one of the above to the back of my 2019 R29S. I'd like a relatively flat fiberglass floor but need to watch the weight also.
Does the WM inflatable have a deep Vee floor?
What is the weight of the RT inflatable?
What model Weaver offset davits are used - assume the same used on either inflatable?
Where can you buy the weaver davits?
What is the price of the Ranger Tug inflatable?
Thanks for your help.
Just a thought: Zodiac has a new style inflatable with an aluminum hull that looks very enticing especially if used near rocky or other dangerous beaching areas and weight seems reasonable.
I can't speak to your choice of RIB's, but another davit system you might consider is Olsen. This davit keeps your dinghy at about 45° to swimstep, effectively adding to your LOA, but it allows for permanent motor attachment, eliminating the need to mount motor with each dinghy deployment. It also allows for better line of sight from the helm.
Our 2016 R-27 had the Olsson dinghy mount davits carrying a 7'10" rib and the 5 HP Honda.
So much easier to use the dinghy without having to hang the OB every time.
The OB stays on the rib.
I like the increased aft visibility.
