Commander Ed
- Jul 16, 2009
- C-248 C
- Sea Dragon
Cruising on Sea Dragon from San Pedro to San Diego (2009 R-25 with 150HP Cummins) - Running at 14 knots for about 45 minutes - engine died. Sudden loss of power very surprising. Trouble shooting - suspecting electrical due to sudden nature of loss of power. Engine battery buss showed 0 volts. House and Engine both normal. Befuddled - hit cross connect on battery busses - still 0 on Engine buss. After about 10 minutes looking into battery compartment for anything abnormal, the battery buss came up to 13+volts. Engine started and fault on cummins display showed an overheat for a moment but quickly returned to normal. Suspecting I might have got some seaweed blocking through hull causing overheat and shutdown - puzzled because it should have given an aural warning before getting too hot - all indications seemed normal, and we proceeded on. (starting to change route to hug coast a bit more)
After 30 minutes - same loss of power and engine battery buss indications. Again after 10 minutes the buss comes back, engine starts and we proceed at reduced power. (vowing to hug coast and looking for possible friendly harbor) Did I mention that the weather is starting to turn crappy and seas are coming up.
Made decision to abort into Dana Point - but power loss happened 3 more times getting into the harbor - fortunately - not in the restricted maneuvering area of the harbor. Glad to be in and at a dock as the weather had really blown up quickly, and bobbing around for 10 minutes every 20 minutes or so made me - the skipper sick. Sick skipper and sick boat - not a good combination.
Raining too much and too hard to do much trouble shooting yesterday - but the symptoms were always consistent - and I don't think it was related to temperature because I monitored it closely and shut downs still happened. Did not seem to matter what the load or RPM were either. Still think it is electrical - maybe a grounding problem?? But not sure if the logic on the Cummins keeps the buss from powering up after a failure for 10 minutes, but will do some reading.
Any ideas from anyone is appreciated - will be completing my journey to San Diego today by trailer. Once in home dock - I will have time to TS and get hold of Cummins. If I learn any lessons - will post at later date.
