Just Limin'
- Dec 7, 2011
- C-26
- Just Limin'
Was running fine today for an hour at 7.5 knots on our R25SC. Noticed that the temp gauge went up from 196 to 197 and saw light smoke from the exhaust. Found almost no water in the strainer. Used a couple of plastic wands to see if there was anything blocking either side of the strainer. Found nothing. Water would fill the strainer until it overflowed. Closed the strainer. Started the engine and all the water was sucked out of the strainer and it made a sound like air had been sucked out and I could see a half inch of the rubber gasket was stretched out. Shut down the engine. Checked the gasket and found it to be in good shape. Let it fill with water, tightened the strainer top down and tried again. No luck. Can't understand why it would be running fine and just overheat, unless I sucked something into the strainer. Was able to limp back to my pier. Will have a diver look at it in a couple of days. Impeller was replaced two months ago. Thoughts appreciated. I think the boat is out to drive me nuts...
