Raw Water not going to the Toilet R25
Lanrac62
R-25 (Outboard)
FMLT2527K233
Sin Nombre
It worked fine when I started it up for the season, but after going out one time, it stopped. I checked the valves, raw water strainer (which was empty), and through-hold. All good.
The possible issue is an air bubble in the line. Does anyone else have this issue? For now, I am using the fresh water from the sink faucet, which works fine and has no raw salt water smell,, but it uses more water than I would like. Any suggestions?
Same issue on mine- only 10 months old. I can hear the solenoid, so I don’t think it’s an electrical issue- and I checked the sea strainer. The raw water line has to be clogged. This issue started, then fixed itself, and has now started again. Not sure what to do about it
