curt
- Oct 29, 2009
- C-24 C SE
- fmlt2107g708
- tugger
The pilot seat bracket support has pulled out from the base of the refridgerator. It was held on by two screws instead of thru bolts. To install nuts and bolts I must remove the refridgerator...it looks like removing 4 screws will enable me to slide the reefer out to get to the inside of the panel to install nuts, backing plate, etc. Is this correct or is there more to it????
