Remove Gas Stove R29
fishheadbarandgrill
R-29 Classic
Sunfish; Vespa GTS 300 Super
Sea Shanty
I have a malfunctioning hinge on my oven door that requires me to remove the stove/oven so I can access a side panel. Has anyone moved the oven/stove before?
Bob
If it the same one I have (Princess) there are four screw, on the sides on the burner top and then four screws at the bottom on the front. Then slide out a bit and remove the Propane connection. Pretty easy.
Thanks. That sounds easy enough.
