Removing key on propeller shaft R29
DaveandEileen
C-288 C
FMLT2909G011
Miss Betty
We recently purchased a 2011 Ranger 29 with a Yanmar 6BY2 260 and it is being serviced.
The cutlass bearing is bad and they are pulling the propeller shaft. The mechanic is having difficulty removing the key holding the shaft in because of very tight space.
Does anyone have advice?
Dave
Are you talking at the transmission coupling? If it is it is also tapered and you will need to remove the bolt that at the end once the coupling is separated. You can try to then reconnect and use a slip hammer threaded into the prop end of the shaft. Once the coupling is off the key should be able to be tapped out.
I'm amusing you are talking about the engine/shaft coupling removal. The Prop shafts used are double taper shafts. The prop is located on a taper and the coupling is too. The access to the engine coupling is limited by boat design. There are a few ways to get the coupling off. My first attempt would as follows.
Loosen and remove prop nut
**Remove the prop ,this may require a prop puller to "pop" it off the taper
**Reinstall the prop loosely ( don't tighten nut leave loose)
**Remove coupling bolts and slide the coupling to the packing gland
**Remove the nut located in the bore of the coupling ( this may require cutting a socket down for clearance.
**Put a block of wood between the hull and the loosely installed prop with key. This will lock the shaft for loosening the coupling nut.
**Once the nut is loosened and removed. Remove the block of wood and prop. Slide the coupling back to engine coupling and bolt back together snug not tight.
**A slam hammer is needed with an adapter, threaded portion on one side that matches the shaft thread. This may be purchased or made. Many boat yards that have service centers have an assortment of these. The opposite side of the adapter will have a thread size for the slam hammer shaft to thread into.
once the slam hammer is properly assembled to the prop shaft use the slam hammer to "pop the shaft off the taper.
**When the shaft breaks loose of the taper remove the shaft key from the shaft loosen the packing gland all the way for removal and slide the shaft out. There is clearce for the shaft to be removed because of the offset rudder.
If this doesn't work the technician is going to have to be creative. The space is limited but a small puller could be made and used to remove the coupling from the tapered shaft.
Last resort would require destroying the coupling. Using a cutoff tool to cut the coupling off the shaft. This requires a lot of patience and steady work. If this is done make sure there is some type of fire blanket used to cover and protect components in the engine compartment from grinding dust and sparks ( this is the last resort method) If this method is used I would recommend purchasing matching couplings engine and shaft to confirm proper coupling balance.
I was typing this while Mike answered so the post is redundant. I didn't see his post.
