Replacement port light screens
harley
I need to replace the 6” screens on a 2010 Ranger 21 EC.
Can someone point me to a source and know what the brand of the Bronze 6” port lights from that era?
Thank you,
Runcible
I actually removed the screens and cleaned up the frame smooth. I bought a piece of typical nylon screen. Cut the circle. Put a piece of wax paper on a counter. Put a small bead of clear silicone around the whole frame. Laid the screen on top of the wax paper then the frame on top of that. Let it sit overnight and then peel the wax paper off. Never had to replace it again.
Harley, You can purchase stainless steel woven wire mesh screen material size 8" X 11" a pack of 4 from Amazon for about $13. Then do as Mr. Knotflying suggested, I would add if you glue the support rail to the whole piece of screen and once dry then cut/trim it would be easier and a cleaner result.
Good luck and let us know how it comes out a picture would be nice! Bob
So does this mean there is no direct replacement you can purchase...I see them for sale for some brands and sizes?
Hello,
You should be able to purchase those direct from us via parts@rangertugs.com. Best to have some pictures since the boat is a 2010 so we can ensure getting you the correct parts. Hope this helps!!
