Capt’nKarl
- Feb 22, 2013
- C-242 C
- FMLT2330I718
- Non-Fluid Motion Model
- Previous R-21EC
- DRAGONFLY
2018, R-23. The deck down switch has stopped working. As I explored replacement I discovered the switch that came on the boat is no longer available. I believe it is a CH switch. The replacement switch is 15mm larger in diameter and the screw holes are in different locations. Additionally the deck opening for the old switch is 25 mm and the new switch is only 9.5 mm. Here’s my question. What’s the best way to seal the old opening and screw holes to keep water out? FYI, the original opening through the deck was not sealed at the factory as I think it should have. You might want to check this out on your boat.
Thanks.
Karl
Thanks.
Karl
