nzfisher
- Jan 26, 2009
- R-25 SC
- Swims with Tuna
I am in process replacing the water heater on my 2011 R25 sc, in fact, everything in the starboard side lazarette will be replaced as it is a 10/year old boat and I am not finished cruising/ fishing her yet. I have the heater free to slide back into lazarette space and was considering cutting out a section of plywood to allow enough vertical clearance to drop the unit far enough to get it out. I was wondering if there are existing images of what is under there before I start hacking away. I am more deft with wood than painstaking disassembly of metal, and, since it needs to be done twice, out and in, I thought I might try another solution that also offers the next user relief from thoughtless boat design (come on guys building a boat around an element that is nearly impossible to remove is a bit much!). Thanks for any leads or suggestions.
Swims with Tuna
Swims with Tuna
