At the Bremerton Rendezvous I noticed several boats having light-weight small diameter lines attached to the bottom of their fenders. I assume this line is to make it easier to retrieve the fender by pulling on this line rather than hauling the fender up using the line attached to the top end of the fender. Do I have this correct ? If so, just how much easier is it and does the extra line cause any issue with fender storage when underway ?
I can see that this technique for fender retrieval would or could be a good solution for our R-25's port side front fender. My 1st mate does have trouble pulling up this fender as she has to lean out the front port side window and heave up the fender and jam it into the vertical rail too secure it. However, I'm struggling with how much easier it would be if there was a small diameter line attached to the bottom of this fender as it seems there's one more line to store and secure and there's no relief for her having to lean and stretch her arm out the window!
More often than not, I simply jump over to the port window while kneeling on the seat and heave in the fender quickly and secure it. The extra line attached to the bottom of this fender seems to me to be rather superfluous and more of a hindrance than being beneficial.
Comments welcomed. 🙂
