vjdup":3pxm82k3 said:Is there a way to use raw water?
knotflying":1my6en0r said:vjdup":1my6en0r said:Is there a way to use raw water?
Not sure what you are asking. The a/c unit sucks raw water up and out a thru hull on port side forward. If you are in fresh water than it is fresh water. If you are in salt water then it is salt water.
vjdup":961rfqcf said:I wonder if theres a 3 way fitting that would allow the fresh water tank for winterizing.
Irish Mist":103wqkac said:Seeing as you are in Alaska.I'm wondering as you say a winterizing valve was installed that is hooked up to supply antifreeze to Freshwater pump, Generator and A/C unit , If left in the wrong position could have all these pulling water from the fresh water tank through a back feed from the water pump, That would explain why the generator stops when the A/C stops .. they are both out of fresh water. This would be something a previous owner would have installed ... not a factory option.
Please let us know what you find as a few of us are anxiously waiting to know the answer 🙂
Good hunting.
